jfarrell2011
Jan 01, 2012Aspirant
Seagate ST2000DL003 3.5" Barracuda Green Hard Drive
Hi, I am a little confused according to Netgears hardware compatibility page it states the following: "You trust us to protect your data so we take it upon ourselves to list only drives that hav...
hoss713
Jan 06, 2012Aspirant
I don't know, but I'd suspect your Duo if you're getting the same problems with different drives...
I've got my NV+ v2 with two of these drives installed in a RAID 0 configuration (no mirroring) and copied over several hundred GB of data using Time Machine, rebooted and did a volume scan which came back with no errors. Next test is to copy over some data by dragging/dropping, the reboot and volume scan again...
EDIT [01/07/2012] Just copied about 60GB over to a share on the NV+ v2 and did a reboot/volume scan and no errors reported...
-lj
-lj
