toto4
Jun 04, 2012Aspirant
Seagate ST2000DL003-9VT166
All, I have a readynas Ultra 4 with (3) 2TB Seagate ST2000DL003-9VT166 -302 drives in it. I have firmware CC3C that came with the drives. I have read the issues people have had with these drives. I...
dkerr
Jun 29, 2012Aspirant
The problem will not appear in 12 hours. It could be several weeks, then one day you'll get a drive failure detected email (make sure that you have email alerts turned on and test that it works). The channel will report as "dead". Sometimes simply shutting down, turning off and turning back on will cause the volume to resync. Sometimes you need to take the drive out, "erase" it elsewhere and plug it back in to cause the resync.
My last failure was June 21st. Prior to that was June 12th... June 2nd... May 22nd... March 23rd... March 11th. You get the idea -- these are not drives you can trust.
DAK
DAK
