toto4
Jun 04, 2012Aspirant
Seagate ST2000DL003-9VT166
All, I have a readynas Ultra 4 with (3) 2TB Seagate ST2000DL003-9VT166 -302 drives in it. I have firmware CC3C that came with the drives. I have read the issues people have had with these drives. I...
Sandshark
Oct 08, 2013Sensei
I read a few threads on adjusting drive timeout values in Linux - noting that no one claims success & not having much else to do I applied the method and have flogged the unit for 2 weeks now with no dead drives. It seems pretty stable. I cant say if its just luck or if it actually works. Time will tell- if you would like to try it - here it is.
After a reboot (can be automated via /etc/rc.local), I run the following commands:-
echo 300 > /sys/block/sda/device/timeout
echo 300 > /sys/block/sdb/device/timeout
xxxx
Default is 30 - I do this for every drive in the raid group. In the Ultra 6 it ends up being for sda, sdb, ..... sdf
Give t a try..... If it continues to works ... it saves me going and getting WD red NAS drives.
I. too. am very interested in how this holds up. It still doesn't explain why going back to RAIDiator 4.2.21 has fixed the problem for me, though. To me, that clearly indicates that there is a fix that Netgear could implement if they only had a clue what they changed (intentionally or not) in the 4.2.22 update that affected this. The default timeout in 4.2.21 is also 30, so that's not it. I would like to update RAIDiator on my NAS's, but dare not due to this issue. I keep the ones without the ST2000DL003's at 4.2.21 also, in case the NAS with them has a hardware problem and I need to swap the disks to another.
I ran more than a year and a half with these drives with no problems. Upgraded to 4.2.22 and had problems within a week. Downgraded to 4.2.21 and have been going strong for another year. Yeah, it's a Seagate problem. :roll:
