toto4
Jun 04, 2012Aspirant
Seagate ST2000DL003-9VT166
All, I have a readynas Ultra 4 with (3) 2TB Seagate ST2000DL003-9VT166 -302 drives in it. I have firmware CC3C that came with the drives. I have read the issues people have had with these drives. I...
justinT
Dec 22, 2013Aspirant
Hi,
That link to the firmware doesn't work! Could you possibly check it again and repost?
I have a ReadyNAS 4 ultra plus with three Seagate 2T drives - everything has worked fine for years (Aug 2011). Two are CC32 (has since purchased NAS) and the newest is a CC3C disk (1.5 years ago). That has just failed last night - interestingly after the disk integrity checking was scheduled for the first time - also FW just updated a couple of days ago. Don't know if there is a link to this drop out from the readynas disk checking function?
Anyway, I would like to try to update the firmware to the CC3D if a link can be found!
One other point. I checked Seagate warranty checker - it said the disk was out of warranty. I've had it since May 2012, it has DOM as 10/2011.... aren't these supposed to have a 3 or 5 year warranty?
Was about to buy a 4th disk... any recommendations on current compatible 2T disks?
J
J
