enbeekay
Aug 25, 2012Aspirant
Seagate ST3000DM001-1CH166
Hi. I got my ReadyNAS NV+ v2 earlier in the month and got 3xST3000DM001 (as i couldnt afford a 4th at the time). Those 3 drives were ST3000DM001-9YN166 drives which updated to firmware CC4H fine a...
Feb 28, 2013Guru - Experienced User
I've switched over to Red drives also, and have been quite happy with them. In my case I am retiring WDC green drives (which I don't recommend for NAS even if they are on the HCL). I also have some seagates deployed (2 in the Pro, and 2 in the Duo v1), but unless something changes I will replace them with Reds when the time comes.
gibxxi wrote: I agree with PapaBear. The WD Reds are designed for 24/7 NAS usage scenarios. Seagate have been having consistent issues of late just getting their drives TO WORK AT ALL. TBH, while they aren't a bad company on the whole, in terms of reliability, I'd avoid Seagate drives for NAS usage at this point in time. The WD Reds are more expensive, but you are buying piece of mind here. It's YOUR data, are you prepared to put it at risk for a few £/$ less?
In addition to gibxxi's comments, both Netgear and WDC agree that the WD Reds work in ReadyNAS, which should simplify dealing with support from both companies. They also have a 3 year warranty, which is longer than the normal warranty for consumer drives these days.
