pixel81
Sep 21, 2008Guide
Seagate ST31000340AS drives making click-clunk sounds
I upgraded my ReadyNAS Duo from a pair of Seagate 500GB drives to a pair of 1 TB Seagate ST31000340AS drives (listed as compatible drives on the Hardware Compatibility List: http://www.readynas.com/?p...
ebolasmurf
Sep 24, 2008Aspirant
Zappes wrote:
ebolasmurf wrote: I hear the "bzz.. click click" sound in 5-10 min intervalls...
Have you activated spin-down? And would your spin-down interval be 5-10 minutes? In that case your problems sounds a bit like the one jeroen1000 and me discussed in another thread: viewtopic.php?f=24&p=114101#p114101
In that case I wouldn't hold my breath waiting for someone to help you - absolutely nobody at Netgear cared about Jeroens and my problem even though it was extremely well-documented and verified by separate sources. Once the guys have your money, they don't seem to care too much about your problems with their product anymore.
ebolasmurf wrote: Its brand new discs that I got when I bought the ReadyNAS..
Yeah, that happens. The Seagate in my ReadyNAS Duo had the "overheat bug" from day one and had to be sent to Seagate for exchange.
Spindown isnt activated... I turned everything "extra" off. Only use it for storage of .raw files from the dSLR.
Sounds weird if both drives would be deffective from the start...
