a_carneiro
Apr 06, 2012Tutor
Seagate ST33000651AS vs ST3000DM001
Hello, oh great fountains of all knowledge... I was looking at 3TB HDDs and would be keen to consider the Barracuda range of Seagate drives. Although the ST33000651AS is in the HCL, it doens't see...
ReadySECURE
Apr 06, 2012Apprentice
PapaBear is absolutely correct here. The drives that show under your device on the HCL have been fully tested and proven to function correctly with that particular ReadyNAS device. Some appear on lists that aren't on others. So it is always best to find one that is compatible with your specific ReadyNAS so that you won't experience some strange issue with a drive that hasn't been tested; or failed to make the HCL for that particular NAS.
