TeknoJnky
Oct 31, 2011Hero
Seagate ST4000DX000-1C5160 [3726 GB] 4TB
firmware cc42 date 12047 dom 7/2011 bare drive pulled from usb3 external @ http://www.amazon.com/Seagate-FreeAgent ... 914&sr=8-1 single drive, boot menu factory defaulted, all frontview default...
mdgm-ntgr
Dec 29, 2011NETGEAR Employee Retired
14884gb is actually about 14.5TB. The GB measurements shown in Frontview treat 1KB = 1024 bytes, so your calculations should show 14884 / 1024 = 14.54 TB. Using 1KB = 1000 bytes you'd get 14884 / 1000^3 * 1024^3 / 1000 = 15.98TB. The overheads are actually quite minimal, it's the differences in measurement units that explain most of the discrepancy. Of course there is a 4GB OS partition on each of the disks that is on a separate partition.
My estimate of 11TB in my post above was an overestimate, I had been thinking about number of GB / 1000 too, so i would actually be a bit under 11TB with 6x3TB disks.
