TeknoJnky
Oct 31, 2011Hero
Seagate ST4000DX000-1C5160 [3726 GB] 4TB
firmware cc42 date 12047 dom 7/2011 bare drive pulled from usb3 external @ http://www.amazon.com/Seagate-FreeAgent ... 914&sr=8-1 single drive, boot menu factory defaulted, all frontview default...
longshot94
Jan 24, 2012Aspirant
mdgm wrote: longshot94, using it in RAID-0 if one disk fails all data on the volume is lost. Four RAID-0 volumes would be a good option provided you can split your backups into separate backup jobs with each backing up less than 4TB.
It's 4TB not 4GB. Similarly 3TB not 3GB.
Yeah I could split it up I guess until my movies folder exceeds 4TB which its getting close. If I loose the volume i will replace the disk, re-create the volume, and copy all the data back on next backup run.
Yeah typo have been fixed from GB to TB :)
