TeknoJnky
Oct 31, 2011Hero
Seagate ST4000DX000-1C5160 [3726 GB] 4TB
firmware cc42 date 12047 dom 7/2011 bare drive pulled from usb3 external @ http://www.amazon.com/Seagate-FreeAgent ... 914&sr=8-1 single drive, boot menu factory defaulted, all frontview default...
mdgm-ntgr
Mar 23, 2013NETGEAR Employee Retired
There are two expansion limits. One of them is that you can't expand your volume by more than 8TB over the life of the volume. What was the capacity of the volume when you last did a factory reset?
If your volume is using single-redundancy then you would be running into the limit that you can't expand past 16TB
