TeknoJnky
Oct 31, 2011Hero
Seagate ST4000DX000-1C5160 [3726 GB] 4TB
firmware cc42 date 12047 dom 7/2011 bare drive pulled from usb3 external @ http://www.amazon.com/Seagate-FreeAgent ... 914&sr=8-1 single drive, boot menu factory defaulted, all frontview default...
TeknoJnky
Mar 24, 2013Hero
well I bit the bullet and did the offline expansion documented here, and while the expansion seemed to go ok with no errors, the fsck after the expansion had a bunch of errors that I let it fix which was worrisome, but from what I can tell all data is ok.
While trying to install lsof, I screwed up my sickbeard install so now that seems to be the only thing not working right.
sauron:/c# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 2.2G 1.7G 57% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 15T 9.2T 5.4T 64% /c
/c/backup 15T 9.2T 5.4T 64% /home/ftp/backup
/c/media 15T 9.2T 5.4T 64% /home/ftp/media
tmpfs 50M 0 50M 0% /var/replicate/shm
