ABTSTech
Jun 19, 2012Aspirant
Seagate ST500DM002 Hard Drives
Do Seagate ST500DM002 hard drives work in a ReadyNAS Duo v1 RND2150. I have a customer with a failing drive but am unable to purchase any of the drives listed on the hardware compatibility list as SA...
mdgm-ntgr
Jun 19, 2012NETGEAR Employee Retired
There are some SATA III (6Gbps) drives on the Hard Disk HCL
I would like to see more disks qualified but do stick to those on the list.
If your backup is not up to date I would suggest you ensure it is as a first step.
