depasseg
Jan 18, 2012Aspirant
Separate data (volume c) and system volumes
I find it hard to understand why the system volume is not an internal device instead of being resident on the drives that are placed in the chassis. An SD card or USB or something else mounted inside...
PapaBear1
Jan 19, 2012Apprentice
TeknoJnky wrote: Personally I am happy that the OS/config are stored on the disks, this means that everything travels with the disks, ie you can remove the disks (as a set) from one readynas, and put them in another readynas of the same architecture (as a set) without any issues.
Amen. When I purchased a second NVX (Business Edition) to supplement my NVX (Pioneer), I moved the data set intact from my Pioneer to the BE and the ONLY thing that changed was the MAC address. The Host name remained and all my share mapping was intact. On this forum we have had numerous episodes where a unit was RMA'd and when the new unit arrived, they inserted their disk set intact and the unit booted up as if nothing had happened. The user appreciated that and many were amazed at how easy it was. I actually consider the fact that the OS is on the disks a very beneficial feature. But then, I am just an ordinary user, not an IT whiz.
