Ylle
Feb 11, 2024Tutor
Set up rsync from Synology NAS to Netgear Ultra 6.10.8
This is the settings for the Synology NAS. "Backup_Stor-NAS" is the destination file share on the Netgear. I am not sure what a backup module is. However the Synology NAS accepts the settings. ...
- Feb 12, 2024
I would say it is on the ReadyNAS side.
You are using rsync backup, but you are showing us you smb setting on the ReadyNAS.
Make sure the rsync setting on the destination folder allows "Read/Write". The default is "Read" only. Obviously, you can't back up to a read-only folder.
