andreofgyn's avatar
andreofgyn
Setting the correct time zone for Brazil (Ultra)
I had a hard time setting the correct time zone for Brazil now that DST is over and ReadyNas Ultra doesn't have any time zone compatible listed in system/clock on frontview.
If I set the clock manually, filename's creation date become wrong because of the time zone, so, I figured out one easy way to resolve this:
I edited frontview's clock.html and created a new item with the correct time zone for Brazil (since debian support it).
You will need SSH (tested on the latest firmware: 4.2.22):
Simply copy the below clock.html to /frontview/ui/resource/html/system (yes, make a backup and overwrite):
https://www.dropbox.com/s/ytwlrufbotbo4dg/clock.html
Refresh frontview, go to system/clock and you will have a new option (GMT -03:00 São Paulo, Brasília) to select and apply.
For Brazil, I recomend set the NTP to:
a.ntp.br
b.ntp.br
Done!
ProSupport for Business
