HendrikH's avatar
Sep 02, 2017
SFP+ network card
Hi,
is it possible / supported to add a SFP+ network card into a ReadyNAS 628X?
thanks,
Hendrik
  • Hello HendrikH,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Marty_M
    NETGEAR Community Team
  • Marty_M's avatar
    Marty_M
    NETGEAR Employee Retired
    Hello HendrikH,
    As of the moment  ReadyNAS 628X does not support  SFP+ however this can be considered as a feature request and I would recommend to raise this to the Idea Exchange board of ReadyNAS. Adding a kudos would help and if the post does gather a lot of kudos Netgear may consider adding it in the future.
    Marty_M
  • Marty_M's avatar
    Marty_M
    Hello HendrikH,
    Marty_M
ProSupport for Business
