h8ohmh
May 09, 2021Follower
Shell script for displaying RN 214 LCD messages
Hi everyone, I made a small ssh shell script for displaying texts on Readynas 214 (or 204) OS6.0.xx LCD Display (e.g. for messages of an end of a ssh shell programm). Have fun with it! Name it a...
8ohmh
May 10, 2021Guide
I got that command analyzing /etc on ReadyNas OS ssh shell. So far have you tried all -h or --help commands with that rn_lcd? In any case try to use "od" command for examining /sbin/ /bin/ and so on. As far as the ReadyNas team have no explicit command for accessing the LCD my script is the best solution instead of installing a huge GB development environtment on the NAS and a PC... As I wrote: No one has to use it, it's free and it does no harm: it relies only on the ReadyNas OS content! You can use even a blinking messages with a shell for ... do; done loop (one lcd cmd displays text for 3s the other one no)
Sandshark
May 10, 2021Sensei
Yeah, I tried all possible help options and got nothing. rnutil itself has a main help screen, but nothing for that subcommand I can find. I may move a NAS with a display into the same room as my computer desk so I can experiment more. Examining rnutil with a hex editor shows options and error messages for some sub-commands, but none for rn_lcd. It doesn't even complain if K is a number or string.
- StephenBMay 10, 2021Guru - Experienced User
FWIW, there are quite a few soft links to rnutil scattered around - including /usr/bin/rn_lcd. These include
antivirus_scan_rootfs apt_wait backup_md bit_rot_event blink bluetooth_event check_ups_drv clamav_event create_bond create_vlans diagnostics disk_chan disk_event_handler dump_sysflags event_push firmware_update get_disk_info hotplug_event md_event mkhomedir_helper remote_access reset_i2c rn_lcd rn_shutdown search_for_key set_mtu shutdown_eda spindown_schedule start_raids update_support_fw_db volume_schedule volume_util
It looks like rnutil will interpret the name of the soft link as a command - and there are a lot more of these commands than show up in the help text.
- 8ohmhMay 11, 2021Guide
hello StephenB,
I know you are here master, and we/me appreciate you all but listing all possible commands WHICH ARE DANGEROUSLY FOR THE NAS IS NOT VERY CONSTRUCTIVE. eg like firmware_update, start_raids are not that what surely anyone of Netgear wants, isn't it?
In my case I just wanted to give a little shell tool for infos on the LCD screen (the other ones I already knew, and beside of that I can "!hexray" and ghidra anything on RN...)
But anyway thanks to you for giving some bad peoples an idea to write trojans with firmwar_update
StephenB wrote:FWIW, there are quite a few soft links to rnutil scattered around - including /usr/bin/rn_lcd. These include
- StephenBMay 11, 2021Guru - Experienced User
8ohmh wrote:
hello StephenB,
I know you are here master, and we/me appreciate you all but listing all possible commands WHICH ARE DANGEROUSLY FOR THE NAS IS NOT VERY CONSTRUCTIVE. eg like firmware_update, start_raids are not that what surely anyone of Netgear wants, isn't it?start_raids is already referenced here, all that is new is that it is a soft link to rnutil. Folks from Netgear have previously posted the commands used to manually update the NAS flash from ssh.
I agree that playing with the commands w/o documentation is risky - though Sandshark and I both have NAS that we only use for exploration. Netgear could deny support if you damage your system with ssh.
But nothing I posted would give much help to a hacker. If they have a ReadyNAS (or download the free VM), then they can easily see all this stuff for themselves.
- 8ohmhMay 13, 2021GuideHi StephenB, just a question: Haven't you asked ayourself about "bluetooth_event"???. Does ReadyNas'es have Bluetooth module inside it or is it just a relict of other Nas'es??? So far lspci, lsusb, /sys/proc didn't show any bluetooth hardware/module in it - or haven't I researched enough Thanks for answer
- SandsharkMay 13, 2021Sensei
There were some ReadyNAS that shipped with a BlueTooth USB module, but Netgear said they never implemented its intended purpose, which was linked to Insight.. Looks like rnutil has some vestiges of that effort, too.
BTW, I was lookling at the display on my latest RD516 acquisition (which i converted to an RN516) and noticed some messages have the characters spaced out. Got me thnking that the K parameter may be Kerning. Since just any number doesn't seem to work, there must be an allowable range or specific values if that is it. Unlike the legacy panel, the newer one doesn't seem to have multiple font sizes.
