Dewdman42
Jun 08, 2020Virtuoso
Shutdown two readynas from one UPS
I have two readynas, running OS6, they are plugged into the same UPS. There is only one USB output port on the UPS. Any suggestions for how to have both readynas setup to automatically shutdown whe...
- Jun 08, 2020
Dewdman42 wrote:
They are connected to the same switch, its not a netgear switch and doesn't ahve any kind of USB port for monitoring the UPS.
Doesn't matter. What matters is that the switch is getting its power from the UPS, so it stays powered up after the power fails.
Dewdman42 wrote:How do I setup one readynas to follow the other readynas over the network in shutting down?
Go to the power page on the web ui, and expand the UPS section.
- Select "remote UPS" as the type
- Enter the IP address of the other NAS as the address.
- Set the user to monuser
- Set the password to pass
Also reserve the IP address of the other NAS in your router.
https://kb.netgear.com/23121/How-do-I-add-a-UPS-to-my-ReadyNAS-OS-6-storage-system
Jun 08, 2020Guru - Experienced User
The normal way is to connect the two NAS to the same switch or router - and protect that switch with the same UPS.
Then enable remote monitoring on the NAS that is connected to the UPS USB, and monitor over the network on the second NAS.
Dewdman42
- StephenBJun 08, 2020Guru - Experienced User
- Dewdman42Jun 08, 2020Virtuoso
That's pretty cool feature! I can't seem to get it to connect though. when I try to create the remote UPS entry, I get the following error:
Failed to communicate with UPS Error in during post proc code: 17003030001
hmm, somehow I managed to get it to connect by making sure the NAME field for the remote UPS matches the name given over on the other NAS for the UPS.
