fesh
Jan 29, 2012Aspirant
Silent NAS wanted
I need to put my NAS in my living room. So it must be as silent as possible.
Thus I don't want a RAID configuration where all disks are spinning, but a JBOD configuration where unused disks spin down after 5 minutes.
Looking on the comparison PDF, only the DuoV2 (too small) and the NV+V2 support JBOD.
However, I saw in the FAQ that it would be possible to configure single disks as RAID-0 and thus simulate JBOD on other ReadyNAS devices (e.g. Ultra4 or Ultra6). Right?
Which 4-6 bay NAS is the most silent one (regarding hardware, isolation, foam, fan noise, case vibrations...)?
Are the Ultras more sturdy than a NV+V2 and thus more silent (when equipped with same drives)?
I want one disk in my NAS dedicated to TimeMachine-backups from two Mac laptops. Two disks dedicated for movies. And a fourth disk for music and general files.
So if I were to play music and otherwise not use the file server, I want the two movies disks to be asleep, and the backup disk to wake up every hour when my Mac does its Timemachine backup, then spin down again for 55 minutes.
And, of course, the whole NAS should go to sleep after 5 minutes idle. So if nobody watches movies or plays music, then the whole NAS should only be awake for 5 minutes each hour (for the Timemachine backup). While I don't really like to unmount the music or movies disks for the NAS to find out that it should consider itself idle, I could probably live with that. But the Timemachine volume must be kept mounted so that backups happen automatically each hour.
- feshAspirant
I drilled a hole in the wall and ran some cables thru.PapaBear wrote: OK, my question is what connection will there be between the NAS and the device playing the movie (AppleTV or whatever)?
Right, not for HD. I used to use WLAN for streaming SD videos to my Macbook, but for HD you definitely need Cat5 or better.If you are planning wireless, I'm not sure that even Wireless N will have enough bandwidth to do it.
I was hoping the NAS could do that, with a simple Behringer U-Control UCA202 USB sound box attached to the USB2 port.In the same vein, you will have to have some device between the NAS and the receiver to play the music.
Or probably I just use my retired PowerBook G4 Titanium for that - just need to replace its (noisy) internal PATA disk with an IDE->CF adapter and install MacOS 10.5 with iTunes on a 8GB CF card (noiseless), hook it up to the NAS and just mount the music disk... At least then I can control it with my iPhone remotely.
I've just got confirmation (usenet) that some Synology boxes do that. The poster only owned a 2-bay box (DS-211), so I don't know whether the 4-bay boxes will do it...I am also in the mind that either all the disks will be spun down or spun up together, not individually. I don't know of any box that will do that.
Hopefully it should NOT be turned off but only sleeping (fan off, processor off, RAM powered), and not boot (30-60 seconds) but only wake-up (2-3 seconds).Also, the drives spinning up is NOT Wake On Lan, that term applies to a box that is physically turned off but then turns on and boots when accessed.
I would only allow booting if it takes less than 5 or at max. 10 seconds, otherwise I'll buy another box!
Problem is that most bigger NAS boxes are only thought of for (small) business, where performance is important and saving power is not, while the home user is thought to use a 1-bay or at most a 2-bay NAS. But with some hundred movies in the collection plus movies plus TM backup, I definitely need at least 4 drives - but still want the NAS to be optimized for saving power and being silent and absolutely don't care about speed as long as it's fast enough for streaming 1 HD movie plus 1 Timemachine backup concurrently.In Spin Down, the box is on and the fan is on. Only the drives are stopped. When you access the unit, even going into Frontview and accessing any section beyond the home page will do it, the drives spin up. The LCD panel will come on and say spinning up. My backup unit is set for spin down after 90 minutes so it is only up during the time it resyncs to my primary NAS during the wee hours of the morning.
Spinning all 4 drives or only 1 should make quite some difference on the electricity bill. And be more quiet.
Netgear should wake up. I think every home user would want to save energy, and have less noise. fesh wrote: I think every home user would want to save energy, and have less noise.
Not me, I want FAST, CHEAP and Dependable!
Energy and noise are at the bottom of my list.
The only truely silent nas, is the one you build your self, with SSD drives and fanless cpu/motherboard.
