bruceread's avatar
bruceread
Simple Connection Question
I have a new ReadyNAS RN10200 and have a simple connection question.  My computers connect to the internet through a mobile hotspot on my cell phone, so I have no physical router to which to connect the ReadyNAS.  What's the best way to connect?  Seems that when I use an ethernet cable it disrupts the wireless connection to my hotspot.
Thanks!
Bruce
  • The readynas must connect via Ethernet to something.
    Does the mobile hotspot (gateway) have an IP address as on a LAN?  and are the computers connecting to it via a wireless LAN that the mobile hotspot creates?
    If this is the case I think you will need to connect the nas to an access point of some sort then incorporate the AP into the LAN.
    You could, as I think you have tried, connect direct to a PC, This will limit the functionality of the nas though as it will not be a LAN device and won't have an Internet connection.
    • StephenB's avatar
      You can get a WiFi extender (or use a WiFi router in bridge mode).  That will let you connect the NAS via ethernet.
      • bruceread's avatar
        bruceread
        Thanks!  And if I connect to a bridge via ethernet, will that disable the computer's wifi connection to the mobile hotspot?  I have a bridge and seems that I tried that but then had a problem with the wifi.
        Bruce
ProSupport for Business
