Platypus69
Aug 13, 2020Luminary
SIMPLE: Does a "factory reset" ALSO perform a "OS reinstall"
Apologies, but it is not clear from support URL below whether a Factory Default (2) process also performs a OS Reinstall (3). From https://kb.netgear.com/20898/ReadyNAS-ReadyDATA-Boot-Menu "Your...
Platypus69
Thanks.
I have "inherited" a decommissioned, out of warranty, diskess RN316.
So I just wanted to wipe it completely and put in some old 4TB disks that I have are lying around doing nothing. So use this RN316 to store data that I can afford to lose.
So I just wanted to make sure I clean up everything as besy as I can, do not want any residual firmware , updates, config, logs, etc.
So the plan was to to a Factory rest and then a memory check. But I was interested in whether i should also lay down a brand new 6.10.3 OS, but it seems the factory reset process does that after it formats the disks.
Thanks again.
Sandshark
Aug 13, 2020Sensei
If you got the NAS diskless, it is already "wiped". No user or configuration data is stored in flash memory, it's all on the drives.
