YE7
May 24, 2017Aspirant
SMB disabled
Hi, I have upgraded the firmware on a RN42200 from 6.7.1 to 6.7.3 and that caused it to loose SMB service. When I click on SMB service to enable it, I hit apply and nothing happens. Thanks, ...
jak0lantash
May 24, 2017Mentor
Did you try to reboot the device again?
Maybe you need to perform an OS Reinstall via the Boot Menu?
jak0lantash
May 24, 2017Mentor
Before OS Reinstall, try to confirm that you're not in a full root situation.
Download the logs from the GUI, look at the end of volume.log, there is a section with "df -h" and confirm that the line with md0 doesn't show the volume 100% full.
- YE7May 24, 2017Aspirant
This is the "df -h" infro from the volume log:
I don't think it's full.
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 804M 2.9G 22% / tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs 3.9G 7.4M 3.9G 1% /run tmpfs 2.0G 28K 2.0G 1% /run/lock tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup /dev/md127 20T 17T 3.0T 85% /data /dev/md127 20T 17T 3.0T 85% /home /dev/md127 20T 17T 3.0T 85% /apps /dev/md127 20T 17T 3.0T 85% /var/ftp/Barracuda /dev/md127 20T 17T 3.0T 85% /run/nfs4/data/Backup /dev/md127 20T 17T 3.0T 85% /run/nfs4/data/Backup2Disk === df -i === Filesystem Inodes IUsed IFree IUse% Mounted on udev 1005843 681 1005162 1% /dev /dev/md0 0 0 0 - / tmpfs 1006497 1 1006496 1% /dev/shm tmpfs 1006497 981 1005516 1% /run tmpfs 1006497 7 1006490 1% /run/lock tmpfs 1006497 11 1006486 1% /sys/fs/cgroup /dev/md127 0 0 0 - /data /dev/md127 0 0 0 - /home /dev/md127 0 0 0 - /apps /dev/md127 0 0 0 - /var/ftp/Barracuda /dev/md127 0 0 0 - /run/nfs4/data/Backup /dev/md127 0 0 0 - /run/nfs4/data/Backup2Disk
- jak0lantashMay 24, 2017Mentor
YE7 wrote:I don't think it's full.
=== df -h === Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 804M 2.9G 22% /
No, it's not full.
- mdgm-ntgrMay 24, 2017NETGEAR Employee Retired
What error messages do the logs show regarding the SMB service?
