nickfitz999
Oct 23, 2019Aspirant
SMB partially Broken after update to 6.10.2 - RN314
Hi, Bit of an urgent post (as if everyones are not) but after a Firware update to 6.10.2, SMB appears to be partially broken. Users can access the shared drives as normal, however they can only ...
nickfitz999
EDIT : Sorted the Workgroup to Workgroup as suggested by many on upgrading - but no luck.
Interestingly, it seems that I can get to most of the other drives, but the one with the data needed......
schumaku
Oct 23, 2019Guru - Experienced User
The workgroup setting is purely organizational and informative, neither authoritative nor restrictive since it was introduced with Windows 3.0 around 1990. Amazing how these tales are still up...
Leaving a corrupt file system alone (a file system check wold be a good idea!), when folders and/or files are not visible or accessible, this is typically caused by effective access loss (easy to happen when co-accessing shares by using NFS, by rsync, ....) due to restrictive Unix protection masks, restrictive ACLs, ... probably paired with the SMB Plus (or manually) added "Hide unreadable" and "Hide unwriteable".
While writing, I would be happy to hear if and how ReadyNAS does allow to force "correct" Unix protection masks and ACLs according to the Share access settings recursively to a complete shared folder tree. AFAIK any changes are just added or removed - the ACLs can't be recreated as on other vendor NAS OS.
