nickfitz999
Oct 23, 2019Aspirant
SMB partially Broken after update to 6.10.2 - RN314
Hi, Bit of an urgent post (as if everyones are not) but after a Firware update to 6.10.2, SMB appears to be partially broken. Users can access the shared drives as normal, however they can only ...
Oct 23, 2019Guru - Experienced User
nickfitz999 wrote:
Users can access the shared drives as normal, however they can only see limited folders (or in this case, 1 out of 100). Rebooted the NAS as well as the users who are suffering. Thanks,
Go to the shares page in the web ui, and click on the settings wheel for the effected share. Then select "settings". Navigate to the file access tab, and then click on reset. That will recursively reset the file/folder permissions for everything in the share, so they will match the permissions shown on the file access page. There should be a pop-up when it completes (it will also be in the log).
