TullyNYGuy
Mar 15, 2016Tutor
Snapshots set to hourly - some are missing #26605970
I’m experimenting with an RN204 and OS 6.4.2. Long term my employer would not use that but may buy an RN516 or RN716. The RN204 is just an inexpensive way to test out the features and functionality o...
- Mar 21, 2016
This issue got bumped up a support tier. I have been working with them and here is what is going on: if disk spindown is enabled, hourly snapshots can be missed. If spindown is not enabled, hourly snapshots are taken each hour as expected. This has been confirmed for OS 6.4.2 and 6.5.0 beta on an RN204. It may apply to other models, I'm not sure. A problem report was logged into engineering to fix the issue.
I want to thank support, which has been excellent, and you folks for your efforts. From my point of view this thread is resolved.
Retired_Member
Mar 21, 2016Hi TullyNYGuy,
Any news?
Can you update the thread with current status please?
(in case someone else encounter the same issue)
TullyNYGuy
Mar 21, 2016Tutor
- Retired_MemberMar 21, 2016
Thanks for the feedback.
If the issue is not resolved yet, it will most likely be in the near future. At least, now we know :)
Glad I could help.
