punx8
Jan 04, 2011Follower
SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL
Hello Installed this today SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL FOR READYNAS DUO NV+ and its running fine in my Readynas Duo RND200.
MAVS
Oct 24, 2011Aspirant
Hi neo25, I've the same problem with my NV+. Installed a new RAM, but it didn't work. Switched back and installed the old modul but it just keeps flashing the blue power LED and nothing else. Did you solve your problem in the meantime? Any solution for this?
