Campus's avatar
Campus
Luminary
Jun 03, 2015
Planned ReadyNAS 516 with Crucial MX200 1TB disks
Hi,
I am currently planning to move an existing physical server into a VirtualBox instance on a ReadyNAS 516. To achieve max performance within the VM I would like to install several Crucial MX200 SSDs instead of classical HDDs in the 516 box. Does this make sense or will I get problems or are there other options I should think of?
Thanks,
Campus
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Do you have the 516 already? If so, can you send me your logs (see the Sending Logs link in my sig)?
    For performance SSDs make a lot of sense. If you don't already have the ReadyNAS you may wish to consider the 716X too as that has 10GBase-T ports.
    Note that you should use disks from the compatibility list.
    If you have issues using Virtualbox you can seek help here but support will be unable to help.
  • I already have a 516 running VirtualBox hosting 4 VMs but based on Seagate ST4000VN000 disks so setting up VirtualBox should not be a problem. The HCL only lists very old SSDs and no current one but I hope I can assume that a modern SSD like the Crucial MX200 will also run without a problem. Do you have any experience with a SSD in a 516? Are all SATA ports the same or should I prefer specific ports for the SSDs?
    The 716x is out because 10GB isn't necessary and the price is insane here in Germany especially compared to the 516 (1000EUR vs. 2800EUR).
    mdgm-ntgr
    The top two ports are SATA III so would work best with SSDs out of the ports.
ProSupport for Business
