punx8
Jan 04, 2011Follower
SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL
Hello Installed this today SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL FOR READYNAS DUO NV+ and its running fine in my Readynas Duo RND200.
drazic19
Jan 02, 2012Aspirant
neo25 wrote: I tried to install a "SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL" CT12864X335 yesturday, but my DUO wont boot up. It just keeps flashing the blue powerled.
Hi I had the same problem on my Duo v1. RAM ordered direct from Crucial:
CT12864X335.K16FY
(1GB 200-PIN SODIMM 128Mx64 DDR PC2700 Pb-Free)
Duo wouldn't boot up. Can someone recommend another RAM module that is known to work?
Thanks.
