punx8
Jan 04, 2011Follower
SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL
Hello Installed this today SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL FOR READYNAS DUO NV+ and its running fine in my Readynas Duo RND200.
PapaBear1
Jan 02, 2012Apprentice
I recommend that you reread all the discussions and the comments that point out that NETGEAR DOES NOT SUPPORT AFTERMARKET MEMORY UPGRADES. Unless you are running a lot of add on applications, a memory increase is unlikely to make a noticeable improvement in the performance of either the NV+ or Duo models.
