punx8
Jan 04, 2011Follower
SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL
Hello Installed this today SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL FOR READYNAS DUO NV+ and its running fine in my Readynas Duo RND200.
drazic19
Jan 09, 2012Aspirant
PapaBear wrote: I recommend that you reread all the discussions and the comments that point out that NETGEAR DOES NOT SUPPORT AFTERMARKET MEMORY UPGRADES. Unless you are running a lot of add on applications, a memory increase is unlikely to make a noticeable improvement in the performance of either the NV+ or Duo models.
I understand this but I am trying to use the DLNA and iTunes service the performance is terrible. The iTunes service won't even start correctly most of the time and I cannot access it's web interface. I fully understand the unsupported statement, however I'm just asking the community if they know of any current RAM modules that work - the risk from that point forward is my own :D
