punx8
Jan 04, 2011Follower
SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL
Hello Installed this today SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL FOR READYNAS DUO NV+ and its running fine in my Readynas Duo RND200.
mdgm-ntgr
Jan 09, 2012NETGEAR Employee Retired
drazic19 what version of RAIDiator are you running? There are performance issues with 4.1.8. If running that you may find updating to 4.1.9 beta (http://www.readynas.com/forum/viewtopic.php?f=17&t=59222) resolves your problem.
