btaroli
Jan 27, 2014Prodigy
[SOLVED] 516 gets "CPU temp exceeded safety threshold"
I've seen temps hit 86C+ with two PLEX (v0.9.9.0) transcodes running at once. I saw it peak up near 72C with just a single transcode, where CPU usage was reported by top at up to 250% (for the process...
Ki_Adi_Mundi
Jan 29, 2014NETGEAR Employee Retired
so box is not used for trancodes now. fan is adjusted in cycles, it may need some time to see fan speed up. The problem here might be the time is too long.
