btaroli
Jan 27, 2014Prodigy
[SOLVED] 516 gets "CPU temp exceeded safety threshold"
I've seen temps hit 86C+ with two PLEX (v0.9.9.0) transcodes running at once. I saw it peak up near 72C with just a single transcode, where CPU usage was reported by top at up to 250% (for the process...
mdgm-ntgr
Jul 18, 2014NETGEAR Employee Retired
I'm thinking now the change might be just for the fan speed being below the threshold. Still if you can try it to make sure that would be good.
