btaroli
Jan 27, 2014Prodigy
[SOLVED] 516 gets "CPU temp exceeded safety threshold"
I've seen temps hit 86C+ with two PLEX (v0.9.9.0) transcodes running at once. I saw it peak up near 72C with just a single transcode, where CPU usage was reported by top at up to 250% (for the process...
btaroli
Jul 28, 2014Prodigy
mdgm wrote: We still support running 4.2.x on the Pro 6.
The changes to better support older models in the software are done as time permits. The focus is still on the new models which the OS was designed for.
I'll have to re-check then. The only thread I ever saw about doing this very clearly indicated "UNSUPPORTED" in the heading. I guess by supported I mean "a user could call Netgear and expect to get phone support for their configuration."
