btaroli
Jan 27, 2014Prodigy
Re: [SOLVED] 516 gets "CPU temp exceeded safety threshold"
I went back to an old beta forum and found notes about setting minimum fan speed, but that was way back on 6.0.1... :) FWIW, the path for these was in /sys/class/hwmon/device, and below I've dumped the values from fan* and pwm*, if it's interesting or helpful to the inquiry.
fan1_alarm 0
fan1_input 823
fan1_min 0
fan1_pulses 2
fan1_target 0
fan1_tolerance 0
fan2_alarm 0
fan2_input 0
fan2_min 0
fan2_pulses 2
fan2_target 27000
fan2_tolerance 0
pwm1 3
pwm1_auto_point1_pwm 140
pwm1_auto_point1_temp 25000
pwm1_auto_point2_pwm 170
pwm1_auto_point2_temp 35000
pwm1_auto_point3_pwm 200
pwm1_auto_point3_temp 45000
pwm1_auto_point4_pwm 230
pwm1_auto_point4_temp 55000
pwm1_auto_point5_pwm 255
pwm1_auto_point5_temp 60000
pwm1_crit_temp_tolerance 0
pwm1_enable 1
pwm1_floor 1
pwm1_mode 1
pwm1_start 1
pwm1_step_down_time 1000
pwm1_step_up_time 1000
pwm1_stop_time 6000
pwm1_target_temp 0
pwm1_temp_sel 2
pwm1_temp_tolerance 0
pwm1_weight_duty_base 0
pwm1_weight_duty_step 0
pwm1_weight_temp_sel 1
pwm1_weight_temp_step 0
pwm1_weight_temp_step_base 0
pwm1_weight_temp_step_tol 0
pwm2 127
pwm2_auto_point1_pwm 140
pwm2_auto_point1_temp 40000
pwm2_auto_point2_pwm 170
pwm2_auto_point2_temp 50000
pwm2_auto_point3_pwm 200
pwm2_auto_point3_temp 60000
pwm2_auto_point4_pwm 230
pwm2_auto_point4_temp 70000
pwm2_auto_point5_pwm 255
pwm2_auto_point5_temp 75000
pwm2_crit_temp_tolerance 0
pwm2_enable 1
pwm2_floor 1
pwm2_mode 1
pwm2_start 1
pwm2_step_down_time 1000
pwm2_step_up_time 1000
pwm2_stop_time 6000
pwm2_target_temp 50000
pwm2_temp_sel 7
pwm2_temp_tolerance 0
pwm2_weight_duty_base 0
pwm2_weight_duty_step 0
pwm2_weight_temp_sel 1
pwm2_weight_temp_step 0
pwm2_weight_temp_step_base 0
pwm2_weight_temp_step_tol 0
