intothevoid
Oct 01, 2012Aspirant
[Solved] Seagate ST3000DM001-9YN166: Load Cycle Count
Hi, sorry if this has been discussed already, all i could find are topics about upgrading the firmware on these drives. I've got a NV+v2 with 4 3TB ST3000DM001-9YN166 disks in it, firmware CCH4 ...
Oct 20, 2012Guru - Experienced User
It looks that way. To confirm it you would need to remove the disk (NAS powered down first) and check the SMART stats on another device (for instance a PC).
HERBIEO wrote: Do you think there could be a bug in this firmware version that is reporting errors that are not really happening ?
because looking at the SMART info there is no errors.
