intothevoid
Oct 01, 2012Aspirant
[Solved] Seagate ST3000DM001-9YN166: Load Cycle Count
Hi, sorry if this has been discussed already, all i could find are topics about upgrading the firmware on these drives. I've got a NV+v2 with 4 3TB ST3000DM001-9YN166 disks in it, firmware CCH4 ...
spett
Oct 23, 2012Aspirant
Found out it does have to have something to do with the NV+ V2. Since I now had a drive with a high command timeout as a sparedrive I pulled out drive 2 which had 0 command timeouts and resynced with the spare drive. Ran a new disk test and once again the command timeouts of drive 1 increased with 30065229831. Drive 2 still have the same amount as before the test.
Googling command timouts i get that this is probably because of a faulty power supply or corroded contacts.
What do you think? Is this a software fault or is my NAS faulty?
