intothevoid
Oct 01, 2012Aspirant
[Solved] Seagate ST3000DM001-9YN166: Load Cycle Count
Hi, sorry if this has been discussed already, all i could find are topics about upgrading the firmware on these drives. I've got a NV+v2 with 4 3TB ST3000DM001-9YN166 disks in it, firmware CCH4 ...
intothevoid
Oct 23, 2012Aspirant
The problem appears isolated to the disk test. So that would seem to rule out the supply and the contacts - they wouldn't mysteriously heal when the test completes.
It is conceivable that the disk test includes some commands that provoke the drive to fail. For instance, malformed/illegal commands, or perhaps legal but unusual commands that the drive firmware doesn't handle properly.
I'd suggest a support case.
In the meantime I would simply not run that test! And record/track the current counts and confirm that they never increase in normal operation.
Is that test run automatically at boot, or on a schedule? I've never manually triggered it.
Both times my drive 'failed' (and had a higher command timeout value afterwards) the NAS was in normal operation.
EDIT: Included quote for top of page clarity.
