intothevoid
Oct 01, 2012Aspirant
[Solved] Seagate ST3000DM001-9YN166: Load Cycle Count
Hi, sorry if this has been discussed already, all i could find are topics about upgrading the firmware on these drives. I've got a NV+v2 with 4 3TB ST3000DM001-9YN166 disks in it, firmware CCH4 ...
intothevoid
Oct 24, 2012Aspirant
StephenB wrote: Seatools will find and test them even if they are in a USB enclosure or USB->Sata adapter. My laptop has eSata, and that of course works as well (though you need an eSata->Sata cable, and a power supply).
Though you can test it (and verify the SMART stats), upgrading the firmware when you are using USB is another matter.
Ah, good to know. Will test it this weekend when i have some more time.
Spett wrote: I think I have ruled out faulty disks by resyncing a new drive in slot 1 and then sync the disc that where in slot 1 in slot 2.
Same result after a disk test, command timeout only increased on disk 1.
Yeah seems like it's not the drives. What do you guys think, time to open a support ticket? And if yes, can I refer to this thread if I make one?
