ArneH
May 20, 2023Tutor
Sparc or Arm
Hej! I have an RND2000 v2 (ReadyNAS Duo v2). Black. Bought 2010-sep-22 I downloaded the RAIDiator-arm Version 5.3.13 (for ReadyNAS Duo v2/NV+ v2) from the hompage with RND2000 v2. When trying to u...
May 20, 2023Guru - Experienced User
ArneH wrote:I have an RND2000 v2 (ReadyNAS Duo v2).
Likely not - the labels are confusing.
The original Duo (called v1 here)
- says ReadyNAS Duo on the front panel
- runs 4.1.x firmware
- uses a Sparc CPU
- might have a v2 label on the back or bottom. This means that it is hardware revision 2 of the (original) Duo, not that it is a Duo v2.
The Duo v2
- says ReadyNAS Duo v2 on the front panel
- runs 5.3.x firmware
- uses an ARM CPU
The 4.1.16 firmware is the latest (and final) firmware release for the v1 Sparc-based NAS.
Note that both 4.1.16 and 5.3.13 firmware were released in May 2017, so 5.3.13 isn't newer.
