Clarkson
Feb 05, 2014Aspirant
Sparc to x86
Hi Why won't hard drives reformat form sparc to x 86 even with a reformat. Trying to reuse 2tb sea gates from a duo to a 312 Cheers John
Feb 06, 2014Guru - Experienced User
The real question is what you can do to work around it.
You can delete the partitions if you connect one drive to a Windows system. Then install on that one, and hot-insert the second.
