Clarkson
Feb 05, 2014Aspirant
Sparc to x86
Hi Why won't hard drives reformat form sparc to x 86 even with a reformat. Trying to reuse 2tb sea gates from a duo to a 312 Cheers John
Feb 06, 2014Guru - Experienced User
It should of course have done it automatically. In your first post you said "...even with a reformat..." Did you attempt to reformat? If so, how?
Do you have a scratch disk that wasn't in the duo that you could use?
If so, you can
(a) install using the scratch disk
(b) hot-insert one disk from the duo in slot 2
(c) after resync, hot-insert the second disk in slot 1.
If so, you can
