dbott67
May 30, 2008Guide
Spec Sheets and Replacement Parts
I figured that it might be a good idea to create a thread where people might be able to obtain information about Infrant-branded ReadyNAS products that may no longer be produced or for products that are out of warranty.
Owners of Netgear-branded products should contact Netgear support.
Anyhow, here are a few links to existing threads that offer solutions, spec sheets, part numbers or third-party replacement items for the older Infrant-branded line-up. Feel free to add your own findings to the list.
-Dave
Spec Sheets:
ReadyNAS 600: http://www.infrant.com/download/ReadyNAS600
ReadyNAS X6: http://www.infrant.com/download/ReadyNAS_X6
ReadyNAS NV: http://www.infrant.com/download/ReadyNAS_NV
ReadyNAS NV+: http://www.infrant.com/download/ReadyNAS_NV+
ReadyNAS 1100: http://www.infrant.com/download/ReadyNAS1100
Cross-reference Table of Duo, NV+, 1100 and Pro:
From this thread:
viewtopic.php?f=24&t=18617#p100422
http://www.bott.ca/files/ReadyNAS_comparison.xls
Determining Revision Number for ReadyNAS 600:
faq.php#What_ReadyNAS_600_revision_do_I_have%3F
Replacing PSU with 3rd Party Power Supply:
If you are having difficulty locating a replacement PSU from Netgear, you can elect to purchase a PSU from a third party, such as Enhance. The NV/NV+ PSU require modification from the standard ATX wiring. A number of users have posted there instructions in thread #1 (below). TrophyGeek & kspades have also posted photos.
1. viewtopic.php?f=11&t=13492&st=0&sk=t&sd=a
2. viewtopic.php?f=7&t=18618
As for the 600 & X6 ReadyNAS, the device uses a standard connector ATX PSU (although the form-factor is different). The only difference between the A & B models is that the 600 Rev. A requires a 20-pin ATX with 4 SATA connections, similar to something like this:
viewtopic.php?f=7&t=18618&p=100893#p100893
The original PSU for the X6/600a/600b was made by Enhance Power (http://www.enhanceusa.com) and was model # ENP-2222F. The A revision of the 600 had 4 SATA connectors, but it carried the same model # as the X6/600b (see pics below by chirpa).
ReadyNAS PSU Pin-out Information:
http://www.infrant.com/download/ReadyNAS_PSU_pinout.pdf
Official NV/NV+ Power Replacement Instructions:
faq.php#How_do_I_replace_the_stock_power_supply_on_the_ReadyNas_NV%2FNV%2B%3F
http://www.readynas.com/download/docume ... %20PSU.pdf
Parts List:
Here are some other part numbers listed from http://www.archive.org's cache of shop-infrant.com:
MAJOR DISCLAIMER: This is cached version of the site as it existed in August of 2007. Parts, prices, availabilty may have changed. This is for entertainment purposes only. :)
-Dave
-Dave
Spec Sheets:
From this thread:
Parts List:
Parts and accessories
Lockable disk tray for Infrant ReadyNAS NV+
Part# RNV2-DTR1
RNV2-DTR1
Price:$25.00
Chassis fan for Infrant ReadyNAS NV+, 12VDC, 92mm
Part# RNV2-FAN1
RNV2-FAN1
Price:$20.00
AC power supply for Infrant ReadyNAS NV+, 100-240 VAC, 50/60 Hz
Part# RNV2-PSU2
RNV2-PSU2
Price:$120.00
AC Power Supply Unit for ReadyNAS 1100, 100-240VAC, 50/60 Hz
Part# RN1100-PSU1
RN1100-PSU1
Price:$140.00
Hotswapple Disk Tray for ReadyNAS 1100, Single
Part# RN1100-TRAY1
RN1100-TRAY1
Price:$25.00
Chassis Cooling Fan for ReadyNAS 1100
Part# RN1100-FAN1
RN1100-FAN1
Price:$15.00
Optional 26" Rack Mount Sliding Rail for ReadyNAS 1100.
Part# RN1100-SR26
RN1100-SR26
Price:$60.00
1GB SODIMM for NV and NV+
Part# 1GBSODIMM
Price:$140.00
Cross flow fan for Version A ReadyNAS 600/X6
Part# RN06-FAN1
Price:$20.00
120mm Fan Retrofit Kit for ReadyNAS 600/X6 Version B.
Part# RN06-B120KIT
ReadyNAS 600/X6 Version B 120mm Fan Retrofit Kit
Price:$40.00
Infrant ReadyNAS 600/X6 (Version A) Power Supply Unit
Part# RN06-PSU1
Price:$60.00
Infrant ReadyNAS 600/X6 (Version B) Power Supply Unit
Part# RN06-PSU2
Price:$60.00
Pre-configured 750GB HDD with Disk Tray for NV/NV+
Part# B750640NS
750GB Pre-configured Seagate ES HDD for ReadyNAS NV/NV+
Price:$470.00
Pre-configured 500GB HDD with Disk Tray for NV/NV+
Part# B500630NS
500GB Pre-configured Seagate ES HDD for ReadyNAS NV/NV+
Price:$240.00
Pre-configured 250GB HDD with Disk Tray for NV/NV+
Part# B250620NS
250GB Pre-configured Seagate ES HDD for ReadyNAS NV/NV+
Price:$130.00
Pre-configured 400GB HDD with Disk Tray for NV/NV+
Part# B400620NS
400GB Pre-configured Seagate ES HDD for ReadyNAS NV/NV+
Price:$195.00
Chassis Cooling Fan for ReadyNAS 1000S (single)
Part# RN1000S-FAN1
RN1000S-FAN1
Price:$10.00
Chassis Cooling Fan for ReadyNAS 1000S (dual fan w/single connector)
Part# RN1000S-FAN2
RN1000S-FAN2
Price:$10.00
ReadyNAS NV/NV+ Disk Installation Screws.
Part# RNV-SCREW
Price:$5.00
-Dave
- chirpaLuminaryGladys,
From NETGEAR HQ, we can only ship out in the Domestic USA. If you are International, will need to find another source, or someone in the USA it could be shipped to.
We have a few of those PSUs kicking around from the Infrant days, so it is possible at this time. The cost would be $20. You can call support (number in my signature below), and ask for the case to be escalated to L3, reference this forum post to the techs, so they know who to get the PSU from (me).
For others reading this in the future, this may not be possible at that time, there is limited supply. - GladysAspirantThanks Chirpa,
I have decided to do some mods and go for the Picopsu. Seems like an OK solution.
It's good to see you still offer the great support I was used to years ago.
Cheers, - GladysAspirantChirpa,
The picoPSU I bought is (I think) underpowered. I'd still be interested in buying two of the PSU's you guys still have lying around. Can you PM me with the details and the info you need from me?
Thanks!
Gladys - chirpaLuminaryGladys, will contact you shortly.
- Davide_NYCAspirantAny ideas if it is possible to purchase one of these?
Part# RN06-B120KIT
Or just the metal parts....
(I can source a 120mm fan) :wink: - chirpaLuminaryNope, zero stock of that left. You would have to fabricate your own.
- Davide_NYCAspirantThanks for the reply.
Zip-ties to the rescue! - nicklebonAspirant
onsetit wrote: I need to replace the fan in a ReadyNAS 1000s. The replacement part is RN1000-S. It is discontinued. Where can I find a 3rd party fan??
Thanks!
Did you have any luck on this? I find myself in the same boat.
Thanks - chirpaLuminaryHow many fans are on the fan header wire? Some revisions had just one fan, some had two fans. I can probably find some spares around the office still.
