MICHAEL2000
Jul 05, 2018Aspirant
SSD INSTAL ON ReadyNAS 214 Series 4-Bay
Does anymoe know how to install SSD on ReadyNAS 214 Series 4-Bay. I have 3.5 to 2.5 adapters but no dice they dont work. They advertise this as compatible with 2.5" drives..
- Jul 05, 2018
There's no need for any adapter.
You need to remove the tool-less insert and screw the disk into the drive tray using the supplied screws. See ReadyNAS OS 6: Adding a disk to desktop models
mdgm-ntgr
Jul 05, 2018NETGEAR Employee Retired
- MICHAEL2000Jul 08, 2018Aspirant
Thanks I will give that a try..
