mps
Apr 16, 2014Aspirant
SSD on Pro
I am thinking of putting Samsung 840Pro SSDs in my ReadyNas Pro. Yes, I know it's not on the HCL but would like opinion. I currently have 2 512GB hard drives and 2 2TB hard drives. Could I migrate the...
Apr 20, 2014Guru - Experienced User
We agree that SSDs are faster than hard drives, and that you see the most gain on random read operations like database queries.
I haven't researched TRIM lately. It was added to Windows, and the only systems I have SSDs in today are Win 7, so I didn't worry about it. I've just assumed it is still needed...
RAID redundancy is great for keeping data available while you repair failures or expand your storage. Though given the relatively small size of SSDs, the restore time from backup isn't that long. I'd still go with jbod to get the most space from the SSDs and restore from backup when/if it fails. I back up daily to other NAS, so raid redundancy is a convenience for me, but not a necessity.
RAID-5 will of course work with SSDs, so there is no reason to think your approach won't work. Either way, it would be good if you post back on your results.
