mobocracy
Apr 21, 2014Aspirant
SSD support for 2120?
I checked the compatibility list, but there doesn't seem to be any listed support for ANY SSDs in the 2120. Are they truly unsupported?
mdgm-ntgr
May 12, 2014NETGEAR Employee Retired
Remember the 2120 has an ARM CPU. If you don't need the rackmount form factor you'd be better off looking at e.g. the 516 or if your budget will stretch the 716.
