netsysengineer
Mar 07, 2018Tutor
SSL RC4 Cipher Suites Supported
My Nessus scan indicates the NAS has SSL RC4 Cipher Suites Supported. The risk factor is LOW so not a big deal but I would like to resolve the issue. I have tried tweaking the httpd.conf, the ssl.con...
Marc_V
Mar 12, 2018NETGEAR Employee Retired
Welcome to the community!
You may want to update to 6.9.3 which contains security updates to the Kernel. CVE-2013-2566, CVE-2015-2808 have been detected on other devices and was resolved through a firmware update.
If you can provide documentation regarding the vulnerability on the ReadyNAS you can check here to report what you have found.
If you can provide us the report you got it would be great as well.
Hope this helps!
Regards
