6speed1
Feb 17, 2011Aspirant
ST2000DL003 Barracuda - 2TB
Has anyone used this drive yet? Any comments? I might order some for my NV+. TIA. :D
swobopio
Jun 13, 2011Aspirant
Alright so it didn't quite work at first but I think it's going to work now.
I just checked up on the progress and it said that the synch of the volume completed successfully but it showed only 2 disks "fully redundant". I rebooted the NV+ which then showed all 4 disks but it still had only 1.8TB usable space (as if only 2 of the disks worked).
I forced a "resync" of the volume and after about an hour it now shows 5555GB usable but will still take about 24 hours for the sync to complete. In short, it looks like it is working now. Will update again in 24 hours when I know for sure :)
