6speed1
Feb 17, 2011Aspirant
ST2000DL003 Barracuda - 2TB
Has anyone used this drive yet? Any comments? I might order some for my NV+. TIA. :D
hoss713
Apr 08, 2012Aspirant
Thanks for the pointer on the logs to get the drive firmware version!
Both drives are running firmware version: CC3C
Based on the date codes, the drives were manufactured on 8/29/2011 & 8/30/2011 and have a site code of "SU".
I'm up to 98% capacity (only 41G free available) running regular Time Machine backups to this unit since March 15 with no problems.
-lj
Device Model: ST2000DL003-9VT166
Serial Number: 6YD16330
Firmware Version: CC3C
User Capacity: 2,000,398,934,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sun Apr 8 06:47:04 2012 PDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Serial Number: 5YD5R0VE
ATA Version is: 8
Local Time is: Sun Apr 8 06:47:10 2012 PDT
-lj
ATA Version is: 8
ATA Version is: 8
