6speed1
Feb 17, 2011Aspirant
ST2000DL003 Barracuda - 2TB
Has anyone used this drive yet? Any comments? I might order some for my NV+. TIA. :D
ReadySECURE
May 01, 2012Apprentice
Due to the use of incompatible hardware, behavior may be erratic and unpredictable. I would suggest returning the drives if you can, and purchasing some that are compatible with the Duo v2.
